Prince Albert Overdrive Note
joelorigo
I am working the Prince Albert Overdrive and I just noticed that the LED hole on the drill template does not line up with the PCB pads. The LED hole is in between the 2 lower pots and the pads are at the bottom of the PCB. Just pointing this out in case someone wants to relocate the LED to right below the pads. Looking forward to hearing this one!
