Ok, color me interested. My Tso's has the same function in my pedal chain but it would be cool to separate the gain and compression controls.
But then, I tend to select certain boosts for certain sounds. Right now my two main goto's that have not left my desk are the LPB-1 and the Modus Operandi. Man I love these two boosts.
You could take an analogous, solid state circuit approach, and get something close. This is what Origin did with the 1176 compressors for their Cali76. That said, there are a number of companies marketing compressors that they say are based on the LA-2A or the 1176—but typically, you’d notice completely different control sections, etc., so I think it’s just shorthand for whatever the knee shape, etc. it’s mimicking, rather than a true circuit ancestry.
I do have an Effectrode LA-1A, which they say is based on the la-2a, and while I have no experience with the latter, the LA-1A is the best piece of musical electronics I own. The circuit uses 2 12AU7s in parallel, so 4 parallel stages of make up amplification, to keep noise level low. I keep it on, at a very low compression setting, with a very soft knee, and short response, by default, but do remember to turn it off every so often, when I don’t want too much of the sweet, round clear notes with crazy separation that it pumps out so effortlessly. Some things just sound better a little raw and sloppy (my playing helps with the sloppy part of that).
Maybe they just are referring to different amps than one might traditionally think. I make a mean amp like distortion pedal. It has LED clipping just like the valvestate amps!
