Recycling enclosure?
Dali
Do you often unbox a circuit and reuse the enclosure?
If so, do you have any tip for removing waterslide decal?
Or am I just too a cheap guy for recycling a 7$ enclosure + few 50¢ knobs?
I'm just curious. :)
I reuse enclosures for my own stuff. I don't use decals though, so it's usually a matter of sanding down/stripping the paint/labels and re-spraying. I sometimes end up using JB Weld to fill extra holes too.
If the water slide isn't sealed you can soak it off, or sand the seal coating off and then soak
You're right, it might do the trick. I put 3 transparent coating on the waterslide sheets before I put them on enclosures. It may be super easy. I will do some testing with scraps I got.
