farwest1
EDIT: SOLVED! It was a faulty Russian Ge transistor. I swapped it out for an NTE 2N404 Ge transistor from Digi-Key, and it works great. When Small Bear reopens, I may try a few other transistors in the socket.
ORIGINAL POST:
I built a Simulcast that will be incredible.....if I can get it working. It has a terrible squealing oscillation problem.
Above 10 O'Clock on the Gain Cut knob, I get a brutal whine/squeal, like feedback. When I play it goes away, but comes back as soon as the signal fades. I've tried different power sources. The pedal is not in a chain. It's direct into my amp.
Here are my theories:
1. Faulty Ge transistor (Russian Ge P416B flat hat.) I am going to order a different Ge type, probably a Rangemaster from the 1970s.
2. Wiring. I adjusted the internal wires to no effect. I may try shielded wire for input/output.
3. Component Tightness. In order to fit the caps and resistors on this board I had to really wedge them in. They won't fit directly above their slots. None of the bare wires or solder joints are touching (I've checked them all), but the bodies of the caps/Rs are touching. Could this cause problems?
4. Wrong Resistor or Cap value. Maybe I installed a wrong resistor somewhere? Would that cause oscillation? I can check them, but I'm really bad at identifying resistors by striping.
5. Blobbed solder. One or two of my joints have "blobs" of solder on them, instead of smooth. Not sure if that could cause an issue. If nothing else works, I'll pull the board out and re-solder some joints.
I'd be so appreciative of any help or ideas! FWIW, several other people on this forum or Reddit have had the same oscillation issue with the Simulcast pcb. It's not clear how they resolved it. And sorry I keep posting about this pedal
ORIGINAL POST:
