Fuzzonaut
I kinda forgot about that SOFTii board and when I finally got around to build it, the build doc seemed to have changed, as some values on the BOM and the PCB were different. I socketed all those and went with what was printed on the PCB. Seems to have been the right move, as it sounds as it should ... at least, I assume it does. The switch kicks in some dirt, I like both settings. I used MPF4293s it called for, from Musikding.
And while I'm here, I'll just add some others builds, with PCBs from other places, as that seems to be ok.
First up 2 Deadend FX things. I really like their choice of circuits and their occasional "add ons", the PCB layout though is a usually a bit, well ... not fully optimized, maybe?
Anyway, here's their take of the LAL Super Oscillo 88, with expression input. A lot of very cool sounds in there. I'm a sucker for anything oscillating.
An the "Wurmloch", which is the DBA Flaming Lips Space Ring, but with a few extras: clean circuit, blend and what I labelled "Spice", which is added crosstalk between the 2 ring modulators. It's tons of fun, if you're into ring mods.
2 Moonn PCBs, both DBA circuits: Interstellar Overdrive and Reverberation Machine with added Feedback (on/off toggle + knob) and Dry Kill (Footswitch).
The OD is cool, although kinda tame for a something DBA. The RM is glorious, adding a hint of feedback brings the "je ne sais quoi" that you immediately miss when turned off. And killing the dry is soooo spooky, amazing.
