Brett
Overall, I'm very happy with this one! The enclosure came out so much better than expected and I'm glad I decided to give Tayda's Matte Black Sand another go. This is two passes of white, one pass of color (using Roland VersaWorks color swatch for the green), and gloss varnish. I think it came out great!
No modifications to the circuit, transistors are TO-92 Siliconix J201 that I had on hand from a Small Bear purchase a while back. Everything biased up well and I ended up using the trick that @Chuck D. Bones posted to set the bias for Q1 (I don't have the link handy at the moment, but it involved tacking a wire between the anode side of D100 and another component, then measuring *I believe* R4?). Either way, it worked so thank you Chuck!
This pedal is very sensitive to pick attack and has a wide range of useful gain available.
