I totally get you, but there's already a UV printing file (3 layers) available for the Sonomatic which has been used succesfully many times, as well as the drill coordinates. In all honesty, these are contributed over the years by members of my FB group, and are freely available for non-commercial use
The (black only) design file for a water slide decal in the building documents has been used succesfully many times without any scaling issues ... It was made with Inkscape, but the exported .pdf seems to work fine. The file for UV printing has 3 layers (color, white & gloss) as per Tayda's requirements, and has also been used quite a few times without any hassle. Also, the drill coordinates available from the files section, line up perfectly with the UV.pdf I'm not sure what else I could say, but everything you need is already out there ... (thanks to our members)@jjjimi84
I had to fix some things up and import the drill plan then scale it to size but I think this is it. I still need to put it into Tayda UV template form but when I'm done I'll forward it.
I used the back minus front command so that the enclosure color would come through the text and control rings but you could easily copy/paste the black outline and put it as RDG_White if you want the lettering, etc. to be white.
Great to hear you've got it fixed!I figured it out. I took your drill file and scaled it properly in Corel Draw and then tweaked the water slide decal to proper measurements.
