Harry Klippton
I've been meaning to finish wiring my pedalboard. I meant to solder cables straight to the input and output jacks on the board, but I definitely need some strain relief.
I installed electrosocket jack cups to the board for the input and output cables, and I'm using switchcraft-style open frame jacks screwed into the electrosocket cups. I've got the mogami 2314 cable, which had an OD of 4mm. It's hard to find cable clamps small enough to hold the cable.
The best solution will be first and foremost elegant and bombproof. What do you think?
