Substitution for 1N5817
bluedmc777
I’m working on a pcb and one of the holes for the 1N5817 is physically smaller in size than the others and the damn leg just will not fit in the hole. Is there a substitute part I could use that maybe has thinner legs? What would happen if I didn’t use it? Would the pedal still work?
you can jumper it and the pedal will still work. The diode is only there to project against plugging in the wrong power supply,
You can also usually substitute a different schottky diode for it if you have other types, they might have somewhat different voltage drops so that is something to keep in mind, but it's usually not an issue as long as it's in the ballpark. But like others said, probably fine to just leave out too.
You could probably gently ream out the hole a little bit without taking all of the plating off. I use an x-acto knife or one leg of some pointy tweezers for tasks like this.
