    Read more…
Super hetrondyne reciever mod
Teddeeh
Hello!
Wonderful pcb and effect.
Is it possible to mod this for dual footswitches
1 for the main on/off
And 1 for a mod for just the fuzz, no oscollation or octave, just pure fuzz,
And also when is thr schematic going to be released for this?
PedalPCB
Administrator
Staff member
Yep, this can be done pretty easily... You'd just need to remove two resistors and move them to the 3PDT, then run a 4 wires (6 if you want an LED indicator as well).
I'll try to get the full docs finished up shortly, then it'll be fairly easy.
PedalPCB
Administrator
Staff member
Move the two 10K resistors highlighted in red to a 3PDT footswitch, then connect the corresponding wires back to the pads where the resistors were removed. Purple wires go to one resistor, green wires go to the other. Polarity isn't important.
You'll have the leftover set of lugs on the 3PDT to switch an LED.
3PDT Wiring
