chip
This is my latest pedal. It's a take on a Big Muff, but with op-amps on the input and output and an active tone stack with variable mids, designed by dylan159 and built on stripboard.
The things I was mostly doing with this were 1) making a white-on-black design and 2) starting to use stranded silicone wire. I feel like I'm starting from zero with this wire for some reason...it's so springy and flails all over the place and I find tinning the ends unnecessarily tedious (compared to pre-tinned solid). I suppose the silicone is nice, but I had a certain amount of skill built up for dealing with PVC insulation and its melting point wasn't really an issue. There's going to be a bit of a learning curve in getting my wire runs as neat as I had them with solid, but I guess this will hold up better over the long haul.
Full write up and more photos are here: https://dunningkrugerfx.com/the-wreck-of-the-ella-fitzgerald
