Chuck D. Bones
Circuit Wizard
You buy the chip from ED? Isn't shipping a bit expensive? Or are you in the UK?
I think it reduces noise and might stop any oscillations. Just guesses based on other schematics I have seen.The proximity of the capacitors to the IC note...is that to reduce inductance between them? If no, perhaps a brief explanation please?
It's got 16 votes on the one I posted for it10 votes on the wish list guys. We can do better.
Remember, the voting is done on the top right area of the post, not the normal "LIKE" for a forum post.
Strymon might have to look at this!!!Investigation & Findings:
The pedal that contained the charge pump mentioned above was a modified Chela as described here and here. I tried another pedal with a charge pump in it, the Crunch Captain Deluxe and observed the same squeal. Next, I replaced the 'lectric Mama with a commercial Flanger, a Monoprice yellow Flanger which appears to be a relabeled Mooer E-Lady. It exhibited the same squeal behavior.
The cause of the squeal is some of the charge pump's 40KHz switching noise sneaks out of the pedal via the output jack. When that 40KHz noise gets into a sampled circuit, like a BBD delay, chorus or flanger, the 40KHz signal is aliased down into the audio range when the sample clock is within ~10KHz of the charge pump noise. When the flanger clock is swept toward the longer delay end on the range, that's exactly what happens. Noise problems like this can be attacked on two fronts: the transmitter and the receiver.
We can make the transmitter end less noisy by filtering the signal before it gets out of the box. The modded Chela, which Cooder aptly named "Rippa," has a PRESENCE switch at the end which varies the high freq cutoff. Either the up or down position of the PRESENCE switch provides enough high freq attenuation to kill the squeal. The Crunch Captain Deluxe has no output filter on-board, so I will have to kludge one in.
We can make the receiver less susceptible by filtering the signal coming in to remove as much of the 40KHz switching noise as possible. I improved the 'lectric Mama's filtering upstream of the BBD by increasing R2 and C4, and adding another filtering stage with R7 and C5. I had to retune the filtering on the output side of the BBD (C9, C10 & R12) to restore the overall freq response. While I was at it, I tweaked the Vref voltage (increased R19) to maximize the BBD's headroom. While all of this helped, it was not sufficient to kill the squeal. It is also necessary to make sure that any pedal containing a charge pump does not transmit excess switching noise.
