TS-808
Coda
I’ve had this on a breadboarding for two weeks. Finally decided to box it up. Sounded off; very muffled, and the gain pot does nothing. Found two mistakes: I had two resistors swapped (R6 and R16). Fixed them and now I get nothing, except sometimes I get this roaring sound,
As if the circuit works briefly. I have found that if I press the op amp down and to the left I can replicate my initial sound, but the gain pot still does nothing.
Pics are attached, I’ll grab some voltages now and edit.
JRC4558D:
1: 1.448
2: .568
3: 5.17
4: 0
5: 2.365
6: 2.367
7: 2.365
8: 8.88
Check what VREF you get on 3 and 5 with the op amp out of socket
With no power to the circuit check resistance between op amp pins 1 and 2 with the drive pot fully CCW and CW
Edit *
With lugs 2 and 3 being connected:
CCW you should get 51K + a few ohms
CW 51K + pot value
Then from pin 1 to R8 side that goes to vref
That should indicate anything funky going on in the feedback loop bad joints, shorts, opens etc
Yes on D1and 2
I am not getting continuity between…those points I mentioned. VREF at pins 3 and 5 is 4.4v. Resistance between pins one and two ccw/cc: 1M/500k
So we know your VREF set ups OK
Resistance in the loop should go down with the pot CCW
Check resistance between lugs 1 and 3 CCW it should be a few ohms CW pot value
Another wee note you've got C4 as 100n not 47 that's a high pass so will only affect that just in case it's not intentional
That was intentional. Its socketed. Am I checking resistance on the gain pot?
Strange your earlier suspicion may be correct either the pots dodgy or a solder joint
With it fully CCW you should get continuity on all 3 lugs It being or should be low ohms CW continuity only between 2 and 3 with them being connected
