Two Tone Fuzz Toggle Settings
VanWhy
I'd like to properly label the toggle switches on my build. If you are looking at the finished pedal, which side of the "MK" is MKII and which side is MKI.V ?
Also, is the Voice switch the same as the original, Mids, Stock, Fat? I'm guessing Stock is in the middle. If so, which side is Fat and which side is Mids?
Thanks in advance.
I have that board and pedal already built out. I'll check in a few hrs when I get to my studio after work and give the pedal a run through. I'll have an answer for you either way
It’s hard to notice a difference between the fat and stock but it may just be my setup the 4x12 cabinlet I have has Celestion g12T-75 and they are not so crisp as I’d like..
Drop C9 down to 10nF and see if you like that better.
I've traced two of these, one had 10nF in that spot which makes a little more sense. (Fat mode switching from 10nF -> 110nF)
