Wild guess: A Banana test jack, panel mount, with solder lug.
But what does it actually do?It verifies the handshakes of the Secret Order of the JFET at the meetings, makes sure there are no interlopers trying to infiltrate the meetings...
Why do you ask? Are you an INTERLOPER?
There are ways of making you talk...
Bring forth the Burning-Tantalum Incense !
It's pretty good at checking for voltage in a 460Vdc panel if you chuck it at exposed terminals.But what does it actually do?
Oh, somebody on Discord figured it out. It's assuming you don't have an auto-ranging multimeter, which means its measuring V, not mV like mine was. So much more sense now.It's pretty good at checking for voltage in a 460Vdc panel if you chuck it at exposed terminals.
But...something about measuring the on and off voltages for Jfets. Something about current too. Honestly, it's above my head at the moment, but that's part of why I built this thing. Gots to learns n things.
Not sure about the x10 bit. Here's the schematic. Brain still waking up...
Kinda like how some octave-up fuzz effects need closely matched diodes,But what does it actually do?
Interesting about matching JFETS. I didn't know that was a thing. I built this and just used it to test that the J201s I bought from eBay were actually J201s and were in-spec. lolKinda like how some octave-up fuzz effects need closely matched diodes,
some effect-circuit builds require closely-matched JFETs, such as some phaser circuits for example.
Several component vendors offer pre-matched JFETs, usually in twos and fours — I've got a project that requires six.
Matching JFETs is time-consuming, thus you pay a premium for vendors' pre-matched sets, but you might still not get the ideal IDSS or Vp specific range you want, despite getting an expertly well-matched set.
Bulk ordering JFETs and then putting together matched sets yourself...
1) Saves yer dosh (opportunity cost is time)
2) Edjumicates you (opportunity cost: possible inaccurate matching as you learn the ropes)
3) Da Dah, Da da DUHHH Satisfaction! of DIYourselfing (opportunity cost: vendor goes under after spending too much on expensive accurate JFET-measuring machines only to have DIYers doing it for themselves like a buncha sistahs... and thus another source of JFETs dries up. MAYBE)
