I built this twin fuzz face from pedal pcb. The silicone side works fine but on the Ge side I can't get less than 8.2v on Q2.
The voltages are wierd all over the Ge side of the circuit. I've tried a different set of ac128 transistors and I get the same results. The voltages after R1 should be 10x what they are. What would cause this? Is C1 somehow dumping voltage to ground? Is that possible? I've attached my voltage readings, a gut shot and a diagram from electrosmash dictating the correct voltages.
Thanks
https://drive.google.com/file/d/11HeCZtQq7UNQSgBajusg15dBdL9xz1_A/view?usp=drivesdk
https://drive.google.com/file/d/11JzXTKd427Umf7C3R2YzHwNdkFP4bMte/view?usp=drivesdk
https://drive.google.com/file/d/11HwKKZ5r85hbMWDtrI2pKyV40K4kqqJr/view?usp=drivesdk
Thanks
