What's in the mailbox? 📬 📦
Given the range I ordered is from 45-150 hfe and the half I've tested so far are under 60, I might wish to return them deeper.
The Soviet data sheets typically measured hFE at a higher collector current than the Peak DCA55 or RG Keen Method, so the data sheet hFE will be higher than your measurements. I'd recommend giving them a try; much of the old common wisdom about the "right" hFE for vintage fuzz pedals is merely a suggestion, or outright wrong in some cases. I've seen measurements from quite a few original Fuzz Faces and Tone Benders where the transistor gains were way lower than the suppsed "right values." (Search for fuzz face collector voltage on the D*A*M forum if you want to see some examples).
Yeh but one of them was a fucking 8.4 hfe lol
What if you combined your MXR Flanger and MXR Filter into one board with one knob...
Hmm a Portmanteau for the name
The FLINTEGER ...
the FLALNTGER
the FLINGER
the FLAILTGER
the FLAINGTER
"Nope no sir, I don't like it." Mr Horse 🐴
Best leave you to come up with a name.
This pedalmith 1590a jig that came in the mail yesterday immediately busted. It’s very rigid plastic and it’s almost too tight to fit. It looks to be a 3-D printed item. I had high hopes. I see another issue if this thing would’ve worked… the holes are too small for a center punch. 🧐
I’ve had nothing but bad experiences buying anything 3d printed. Too many people slinging photoshopped pictures of sloppily made unusable trash to make a quick buck.
