What's in the mailbox? 📬 📦
Got a bottom plate from eBay Japan for mounting a rat on a pedalboard after I lost one of the little rubber feet. I bought one for the crybaby back when I converted mine to a tearjerker only to find out the battery door wouldn't go back on. While these are pricey, they do exactly what they're supposed to do. I imagine some enterprising lads stateside could come up with a 3-D printed version for much, much less.
I figured out how to program EEPROMs for FV-1 builds, now I’m going to trying and learn how to program MCUs but this might be harder than I thought
I went with the Attiny because the whole toolchain is way easier: just an arduino, Arduino IDE and a few cables. And if you’ve done things in an Arduino, it’s easy to figure out what you want to do. I also use a Mac, and a lot of these toolchains are designed only for Windows.
I went with the Attiny because the whole toolchain is way easier: just an arduino, Arduino IDE and a few cables. And if you’ve done thing in an Arduino, it’s easy to figure out things. I also use a Mac, and a lot of these toolchains are designed only for Windows.
I’m running windows, and Know F-all about coding, the tool chain isn’t that bad an IDE, compiler, programmer and the physical tool, others have done it so it’s just a matter of how bad I want it. It’s a lot of work just for a little bit of cheese. But I like a challenge.
These finally showed up (please excuse crappy images, they were taken in poor lighting)...
Switch-mounted Celestial Bypass with chassis ground built in:
Next up is another Celestial Engineering project by the forum's resident guru @Chuck D. Bones. This is the Yankee Screwdriver Deluxe Turbo with on-board Celestial Bypass relay switching for both bypass and turbo functions:
Lastly is another Celestial Engineering project you may not have heard of, The Other Woman Tone (also with built-in relay bypass switching):
Hopefully I can get all of these verified without issue. I'm pretty stoked about all of them and have several more in the works!
Dang dude your circuit design is through the roof! Im excited to see the build reports of these!
I don't know what the other woman tone is, but only one thing comes to mind. If it's not that, I'm gonna be very disappointed
Ok sounds like disappointment then
These look amazing, and "The Other Woman Tone" is an amazing name for a circuit :ROFLMAO:
