Which is pot lug #1 on Thunder Chicken PCB?
miqviq
Hi, I read the fine common guide for building PCB projects, but did not find any mention on how to recognize the correct hole for pot lug #1 on PCB?
I recently bought Thunder Chicken Fixed Wah Kit but in the build guide there are no direct instructions how the pots should be mounted.
On my PCB components side, there is 1 square-shaped hole for each pot. Maybe that is for the pot lug #1?
And is the pot lug #1 the leftmost lug when the pot shaft is towards me?
Or should I just solder the connector cables on the PCB and then figure them out using gator-clips between cables and pot lugs?
-Thanks
Don't forget, pots go on the opposite side of the PCB, not on the side with the components.
