Way to go Paul, you pissed off half the forum.
What? Wait! Did I miss a chance to get pissed off and vent some fabricated outrage? (j/k)
For MZY12:
I actually have a boilerplate sorta answer for such questions as posted in the OP. It's slanted towards beginners and not meant, in any way, to be demeaning. But here it is . . . .
It's kind of important to know from the start that building a stompbox is not really like painting-by-numbers or doing up a Lego project. Many kits make it "look" that easy, but there are several prerequisites to getting a good handle on pedal building. Soldering is a skill that verges on art. Understanding what the different components are and how to determine their respective values and orientation is crucial. Knowing one's way around a DMM (digital multi-meter) is another must.
The build documentation varies from vendor to vendor and range from very detailed, step-by-step instructions to little more than the Bill Of Materials with some notes one how to make connections to the main board. No single vendor can anticipate what level of electronics experience the reader will have.
Then there's the point about what one needs to do when after spending all that money & time to build a pedal only to find it doesn't work. Where would you begin? Would you know what questions to ask? Knowing how to read a schematic is vital. Being able to resource and comprehend component datasheets is yet another facet of aids useful to any bench tech.
To casually build a pedal or two from kits is not that hard. One can get by with minimal soldering skills, the ability to identify and orient components properly on a PCB and be able follow simple wiring diagrams. But to take building stompboxes to the next level, (coming up your own mods, designing you own circuit and\or troubleshooting), be prepared for about a year of really dry reading to truly comprehend electronics. Be prepared for experimenting and experiencing several failures while remaining hopeful about achievements.
There are thousands of discarded, unused soldering irons and cheap DMMs stuffed away in closets across the world from those who thought they would try building electronic things. And to the contrary, there are thousands of successful pedal builders around.
There is no substitute for one's own research. And reading about general electronics is an eventual requirement.
One of the first and foremost points of building effects pedals is that it involves electronics. One does not have to know electronics to begin this pursuit, but electronics will step into the path and it will be key to have a better understanding of how to deal with the electronics aspect of it.
With no clue of what electronics skills, (soldering, schematic reading, and\or general electronics experience you possess), we're hard pressed to point you in the right direction - other than reading. Lots of reading and\or watching video tutorials. Good luck!
That being said; this is a great group and the folks here are really quite helpful - even with the simplest of questions. I think it's safe to say that everyone here is all about learning and sharing what they know & experience. Nothing wrong a good debate when things remain civil.
Even with my personal decades of electronics experience, I often need some remedial reading and/or help with things. Oftentimes, I find myself looking up the schematics of the same circuit(s) from other PCB vendors. This helps me better understand a given circuit and allows me to compare differences, fill in gaps and get a clearer/broader picture of what I'm working on.
For me, pedal building is actually about electronics. And electronics is a fickle mistress. And she does not tolerate impatience, laziness or inattentiveness to detail. She prefers consorts who read up on her ways. She is not faithful, is exceedingly mischievous and stubborn as the day is long.
I believe you're in the right place. And if it's not already been said, Welcome to the group!
