Just finished putting this tremolo pedal together, and I'm getting output but just a volume boost, no tremolo effect. Reflowed some of the solder joints and still have the same issue. Anything I can check for?
I can't remember the name of the shop, guess they might be faulty. I was wondering if that might be the issue. Is there a substitute for that transistor?
Along with checking transistors, you might also double-check for shorts to ground on this side of the circuit. Not an expert on this circuit, but seems like this would essentially force your “Depth” control to zero.
