What's on the workbench?
I'm curous wtbbf is that thing with all the led's and pc mounts pots? almost rivaling my solder table but I know it's from me dragging arse gettign a design for the 'box art' :ROFLMAO:
Which one did you save for last?
The last one was the "Boston Baked Boost", which is basically a fixed EQ set relatively close to Tom Scholz 6-band EQ settings.
Not much fun on it's own, but it's pretty fun in front of another distortion.
I had to adjust a few resistor values so those go into the box of shame. I'll mark out one or two incorrect component values, but anything more than that warrants reordering the PCB.
Ha! (Not really "On the Bench" - but required for the project none the less.) I re-examined my build notes on the rack mounted "Stereophonic Gizmotronic Symphonic Harmonic Perambulator" being built for a client. I had to completely re-work the interface layout to accommodate all that it really does. I may still need to go back and rethink the two Chorus sections to better emphasize the association of the Bypass toggles for each of two dual-chorus circuits.
The two FV-1 "Pythagoras" circuits will be synchronized and use dual-gang pots to manage their respective controls. Nor do they need a Bypass control because that can be achieved with the dual-ganged "Mix"control. The "Volume" control, also dual-ganged, will act as a master volume for the entire effect.
Actually on the bench is a Rockman Ultimatum. The trace has begun!
Anyone who hasn't tried the Golden Faulk ought to, it's the last MIAB I'll ever build (probably)
That is the best MIAB I've tried, and MIAB's are kinda my thing. 😂
It sounds great low to high gain, unlike some that only shine at one extreme or the other.
You can just barely crack on the Normal or Bright controls and get all bluesy and Hendrix like, or dime them and rock the F*$K out!
It's fantastic.
