ICTRock
isn't there already a PCB for this?
Is that hand soldered?? Sounds like something WE would do hahaha
Good thing that unit ended up in the hands of somebody who could fix it and not somebody who'd just return it and leave a bad review.....Ok, resistor is properly installed, time for some Silvertone goodness!
Well.... you'd think. If the Silvertone amps were completely silent this thing is authentic!
There's another issue. So far not blown away.
Is the PDF-2 (or -1) still in your development queue?
That’s a “feature”
I thought Strymon had that market locked up.Aren't these the same church guys selling 300 dollar boost pedals to P&W guitar players? Very Christian like.
That indeed does look cool af. Sorry it didn't work outI redesigned a turret board layout and thought it would look cool in clear, so I cut it from some plexiglass - like the parts are floating.
While it looks cool and sounds great, I'm going to have to tear it down and use FR4. Getting the turret hot enough to take solder also melts the plexiglass. That's why the solder joints look kinda wack.
What's with the white like blotches on the Board?
relicing.What's with the white like blotches on the Board?
I mean, you don't really know that it wasn't.So, in addition to the flying resistor that was never installed, we also have a bad footswitch.
This pedal was clearly never tested after assembly.
Sounds like it was barely assembled.So, in addition to the flying resistor that was never installed, we also have a bad footswitch.
Finally, an original overdrive circuit
