Hey Robert, do you have the drill template for the new "Handy Expression Controllers"? It's obv not too tricky, but just want to make sure the jack is at the right height. I've searched the forums and can't seem to find it. Thanks!
This template assumes you are using a long pin 16mm pot. The PCB should be oriented with the PedalPCB logo facing you when looking inside the back of the enclosure.
And the passive splitter as well, just in case:
For the splitter it's easiest if you mount the jacks in the enclosure first, then drop the PCB on top and solder in place.
You might want to grab an extra washer for the jacks to get the best fit.
Idk if the new ADHD is on the list/requested, but I put all the PCBs together a month ago and don’t want to screw up when drilling the enclosure. Thanks in advance!
Thanks Robert!
Any docs for the Basic Relay DPDT Switch (Latching) please?
It's really not much different from the Latching Basic Relay Bypass Module, it just exposes all six contacts of the relay rather than being bound to a true-bypass configuration.
Just keep in mind the Latching version powers up with contacts A1/A2 and B1/B2 closed, the Non-Latching version powers up with contacts A2/A3 and B2/B3 closed.
Also, there is no onboard polarity protection so you'll want to tap power from a node that is already protected from reverse polarity, or make the VCC connection with an offboard diode in-line. (I do plan to change this at some point in the future)
Echoing my request for a protected courtesy Vcc out on the boards.
There already is one, right here. 🤣
Seriously though, I do like the idea but I'd only want to do it if it could be uniform across all of the projects and that might be a little tricky on some of the dense layouts.
I've considered another version of the DC jack breakout board to include polarity protection and additional filtering, that might be the best way to handle something like that.
