this is a bit old, but do you mean one should use a TC1044SCPA over the TC1044SEPA for pedal building? I was under the assumption (I’m guessing falsely now) the the difference between the two had to do with temperature tolerance?These should also be suitable alternatives. You definitely want the "SCPA" version. (with the exception of the LT1054)
ICL7660SCPAZ ICL7660 CMOS Voltage Converter IC
INTERSIL - Get It Fast - Same Day Shippingwww.taydaelectronics.com
LT1054 LT1054CP Charge Pump Switching Regulator IC
TEXAS INSTRUMENTS - Get It Fast - Same Day Shippingwww.taydaelectronics.com
Yup! Identical otherwise.The “S” suffix is what matters most, as it denotes the boost pin oscillator frequency is above what we can hear (as long as pins 1+8 are connected)…otherwise they are whiny bastards at 10khz.
That’s good to know as I’m doing a dual Klon for a friend that’s going to put a strymon in the FX loop. Will see what happens.I’ll add this issue I had with a TC1044SCPA and a digital pedal.
Whine Sound In Digital Pedal After My Klone
I have a TC Electronic Quintessence that I am getting a whine sound when activated if I have it after my Aion FX Refractor (Klon). I first had both pedals in a daisy chain power supply with some others the I noticed it. Then I gave the Quintessence its own supply and the noise. Then I tired...forum.pedalpcb.com
