A simple Relay Bypass
Heres my attempt at laying out a vero board for this. Have not verified yet! Looking complicated much?
This uses the Kemet EA2-5SNJ found here at the store.
Don’t forget that any change in relay coil resistance prompts a change in the 150R resistor in the schematic. This relay’s coil resistance is 250 ohms where the circuit is spec’d for a relay coil resistance of 178 ohms.
Here's a scoring gauge I just made up:
1 point for each cut.
1 point for each jumper.
1 point for each unused hole. A hole is considered used if it is cut, covered by a component or jumper or used for an external connection.
It's like golf: lower score is better, it can be very Zen and it goes well with alcohol (not too much though).
My score:
12+8+10 = 30
That includes the jumpers on the solder side that join adjacent strips.
Great idea for a thread competition, who can make a Vero layout of a Timmy with the lowest score.
Have you considered increasing the value of the current limiting resistor and bypassing it with a capacitor?
It takes more current to latch the relay than it does to hold, you can lower current consumption considerably.
Maybe something more obscure, there has to be a ton of Timmy Vero layouts on the 'net.
Definitely doable. Relays don't usually have their guaranteed hold current specified. The Kemet EA2 datasheet specifies a "release voltage," which is not the same as "hold voltage" (or current). We would have to measure a bunch and then add margin. The power saved might be around 1/2 of the nominal 140mW coil power. If you really want low power, then latching relays are the way to go. More expensive and more complicated to drive. TNSTAAFL applies here.
Wrong relay. You want the non-latching version.
Wow did not know that! Thank you for that. That just saved me a huge headache!
Ill be out on the look for them. In the meantime im looking for subs that are closely specced to the one you use.
Got it! The pinout is what has my attention, the pinout for the relay i was using is opposite than yours. Its part of the reason i have a rats nest on the vero. lol
Got my PCBs in today. Ignoring the silly location of the SPST pads, it works pretty well and is nice and compact.
Compact enough that I will look at a different layout where the SPST is attached to the PCB (yet still 1590B friendly).
Nice looking board @szukalski! I'm looking forward to see your switch-mounted option for 1590b!
I haven't sent these off for fabrication yet, but they're designed for foot switch mounting in a 125b. *The cutout next to the switch is to accommodate the LED bezel housing.
9V only board:
9-30VDC option:
Edit: I forgot to show a mockup of the side view of this switch-mounted board. The PCB is not to scale but hopefully this gives the idea.
I've been enjoying seeing all the PCBs and faceplates you've designed, they look awesome!
