steviejr92
Authorized Vendor
Yeah just noticed that pretty dang smart. Kudos!
You're looking at the latching coil spec. The EA2 non-latching 5V coil is 178Ω.
Thank you, but I cannot take credit for the idea. I saw it on a switch-mounted relay bypass from Effects Layouts.Yeah just noticed that pretty dang smart. Kudos!
I'd be happy to give those changes a shot.Did you consider using SMDs for the 555 and 78L09? Would free up some space.
Did you have a particular LDO in mind? I try to find parts that are readily available at Tayda but it looks like they don't have any SMD options for an adjustable LDO regulator.An adjustable LDO reg would be a nice alternative to the 78L09.
Hey man you saw a great idea and implemented it. It’s all about execution in my book.Thank you, but I cannot take credit for the idea. I saw it on a switch-mounted relay bypass from Effects Layouts.
Oh, I thought the regulator was only for using voltages over 9v. But I guess the idea is to always have the regulator in the circuit for all voltages, with the ability to adjust for as little voltage drop as possible when using 9v, right? If that’s the case, what about keeping the 78L09 but add a little DIP switch to bypass the regulator when running at 9v?LM317 is not LDO (low drop-out). We need the LDO feature when we power the pedal with 9V. We could easily lose 2V in an LM317.
Thank you, @szukalski! SMD is certainly an option, and one that I don't mind working with. I DO try to design in through hole because if anyone else ends up with one of my boards, through-hole is usually preferred. In deed, the FS takes up a lot of space but it's possible to design around it. I've designed a board for another @Chuck D. Bones circuit in 125b that uses two of these relay switching systems, all through-hole.@Brett @Smrtokvitek - both of your designs are awesome. I think the footswitch-through-board approach is the more practical one (a la Effects Layout), but with added SMD to get the size down. You have to sacrifice a lot of space for the footswitch to avoid shorts, but I think there's enough space to play around with in the SMD world.. a 125B should have enough space for a dual footswitch with relay without causing pain to the PCB..
I made a relay bypass a few years ago with the smallest PIC (10F322) in the product line with SMDs. There is plenty of room if you want to go that way. I really like @Brett s switch mounting. That's the only thing I don't like about my design. I usually use solid wire to secure it to PCB and hot glue.
In general, I think securing any external hardware (switch or jack) to a pcb is just asking for trouble. There’s a risk of mechanical stress if the component fixing comes loose and then the stress is all being taken by the pcb or solder joint.I want nothing more than 9.372 ms
What if you were to change the layout to accommodate the fang style switch? No more glueing...
