jhaneyzz
I had a girlfriend in high school who's father once told here that thunder was the sound of clouds bumping into each other. She never thought about it again because it sufficed.
I started building pedals on vero board and got used to adding current limiting resistors at the point of connection with the led, i.e. on the anode leg.
Everyone knows that different color LED's need different CLR's right? shit might blow up if you get that wrong...
So when I moved to PCB's i just assumed that the board maker didn't know what color LED I was gonna use, so there couldn't possibly be a CLR built into the circuit, so I should just keep my practice of soldering a resistor to the leg of the LED, which, in my builds with fancy wiring is a complete PITA....
I was soldering a bunch of boards the other day and got to thinking (ya know how every damn circuit has a 5817 diode and it turns out that is because every circuit needs polarity protection) I wonder why every damn board has at least one 4.7k resistor? and damn 4.7K gets thrown around as a common value for CLRs. ( I tend to use 1K because I need the extra lumens to illuminate the marbles (or so I thought)
I guess everyone knows the punchline by now...
so now my wiring is going to be even prettier (and a tiny bit brighter)
