Pretty sure once the stroke is put to path it becomes an object like everything elseIt just occured to me that I may be giving myself more work than I need to... The Tayda UV printing site makes no mention of having to convert strokes to paths, but every print I've done in the past, I went throught the file converting everything and carefully correcting each misshapen one, etc...
Anyone able to confirm that I've been wasting my time, and that its totally fine to have strokes instead of paths for any linework and outlines?
Although ? if the stroke isn't put to path will it show up on print pdf? well it shouldn't, but maybe does? I found overlapping stroke on fill a problem. is there a way to set the stroke to expand out from the main body only without spreading in and starting to cover the fill as it does by default? then there's no overlap. So when I converted my stroke to path I noticed a small overlap between it and the fill. I too painstakingly went through and differenced out all these overlaps. I'm trying to avoid stroke wherever I don't need it for that reason. If I could change those stroke settings it would be greatPretty sure once the stroke is put to path it becomes an object like everything else
I've only had an issue with drilling and that was because I left one coordinate as null (it was supposed to be 0 so it looked correct in the preview). In my experience the response was good, but it took a few days. Maybe you can post the file here and we can take a look?What’s been folks’ experience with tayda explaining ‘severe issues’ with artwork files? I’ve had one flagged that I cannot find an issue with, and there’s been no response from tayda help / Hugo.
There's an aesthetic issue with the border I need to take care of, but I don't know what would trigger the flag from Tayda.Maybe you can post the file here and we can take a look?
If I open the file in Acrobat reader, you're missing the gloss layer - not sure if that's enough to trigger an issue. I think you should have it even if it's empty?Thanks. Please see the attached.
I've only ever included it if the design actually had gloss. I've never exported an empty layer. Is that common?If I open the file in Acrobat reader, you're missing the gloss layer - not sure if that's enough to trigger an issue. I think you should have it even if it's empty?
That’s so many.41 holes
Was the order just for drilling or did you also have painting and printing done? 5 days seems an awful fast turnaround if anything more than just drilling bare enclosures. It's been taking my drill/paint/print jobs about 10 days on average of late.My current drill/paint/print order has been there for 4 days and they just finished drilling today.Brief update on the 41-hole monstrosity, Hugo canceled my original order for me so I could reorder, new order (10 enclosures) placed on May 19, shipped May 24.
That was for drilling, powdercoating, and UV print for 10 boxes.Was the order just for drilling or did you also have painting and printing done? 5 days seems an awful fast turnaround if anything more than just drilling bare enclosures. It's been taking my drill/paint/print jobs about 10 days on average of late.My current drill/paint/print order has been there for 4 days and they just finished drilling today.
That's what I do and it works great. For example, when planning for 20mm diameter knobs, create 20mm circles. I use the "center on axis" buttons (for both X and Y) and then the move function and input the drill tool measurements - one of the axis (Y maybe?) is flipped on AI so you need to change it from plus to minus or the other way, but otherwise it's pretty straightforward.I'm just getting started with building pedals and I'm thinking of ordering a few enclosures and getting them printed by Tayda. I've read a few of the guide posts and looked at some of the templates offered by some of the members here, but I have a pretty basic question as I'd like to make sure I have everything lined up correctly.
I'm thinking of starting with the blank template from Tayda and use Adobe Illustrator. If I do this, I'd like to be able to mark exactly where the drill holes will be so that I can make sure the art will fit correctly. Can I simply create a circle/ellipse in AI and set the x/y/d using the exact values from the pedalpcb drill template (such as this: https://www.taydaelectronics.com/datasheets/files/125B-DrillTemplate_4Knob-1.pdf)? Would that place the drill mark exactly where Tayda will drill it (especially if using the pre-drilled enclosures)?
I looked at one of the art templates provided by one of the members, and in those cases it looked like the knob placement for example was off by a few mms compared to the drill template. I'm not sure if this is just due to the way I imported the files, or if that placement there is indeed correct, but if my basic method mentioned above would work then I wouldn't mind just going that way since it's not too much work.
