What’s on *YOUR* workbench?
I need to buy a guitar pedalboard - been using the floor so far - and I'm torn between three form factors: one long row of pedals next to each other like a nano Max, one row plus another one on top of pedals oriented horizontally and two rows like you have here. Can't decide...
There are merits to both I think. I kind of don't like stepping over the first row to get to the back but I also don't want it to be a meter wide
Have you considered putting them on the wall and kicking them like @dawson ?
Really it comes down to what kind of available space have when you’re gigging? If you’re not gigging, see what works for you and your line of sight. I kind of like to have a very narrow files of view that doesn’t distract me from what I’m playing.
I just bought a pedalboard this week (should be here tomorrow), and I just went simple: "Give me your largest board", I said to the Thomann webpage. "Or actually make that largest AND cheapest!". So I got a Spaceship 80 coming in.
If it's not obvious I won't be gigging though, and I'll move the Quad Cortex there too eventually which will take up a bunch of real estate, and the expression pedal of course.
Just boxed a Deofol (the newer revision).
I don’t know why this doesn’t get more noise? It’s a great sounding pedal and lots of usable tones to play with.
If anybody could go ahead and confirm that the 12k won't mess with the circuit too much, yeah that'd be great, m'kay?
Here's the full schematic, look for R8 and here's a screenshot. Is 12k ok or should I desolder and use 13k? Thanks
Use a 13 k, I'd say. That op-amp is intentionally biased at a specific voltage that's less than mid-supply. If you use 12k, it will affect the range of cho_rate, from what I can see. Then again, maybe it will affect it in a way you like. No harm in trying.
So, I assembled a Rock Mania last night and by the time it was all done, I realized that I had forgotten to solder the battery clip. Rats! It's soldered to the top side of the main board, so I had to take it all apart again to get there. But hey, think positive! I took the opportunity to make a video on how to disassemble and reassemble the thing - for the benefit of both my future customers 😂.
Anyhoo, I thought maybe I should link it here, in case it gives someone some ideas on how to avoid wiring at all costs - like I did. There are only two wires in the pedal -- both from the battery clip I had forgot to solder...
Did I mention I hate wiring?
I bet that chromium looks killer in person. thats a cool idea having the chromium enclosure color be part of the pigs armor design. very well thought out!
