eliosvanpizza
I'm thinking of building another compressor. Looking for opinions or thoughts on these.
I've built the Delegate Boneyard edition. I think I messed up somewhere because it is EXTREMELY subtle. I can't get a squishy comp tone but it works well for sustain and boost. I'm thinking of building something that doesn't rely on a photoresistor.To answer, I'd have to have built them all (I my have played through some version of each)...which have you built and what are you looking for in a compressor?
I'm just guessing that there would be some people here who have built 2-3 different kinds. I think I've built 5 overdrive/distortions so farTo answer, I'd have to have built them all (I my have played through some version of each)...which have you built and what are you looking for in a compressor?
I will definitely look into the General Tso. I am hesitant to use photoresistors again but I'm willing to try again.I voted Delegate Boneyard despite never having built (or played) any other compressors.
But that's the kind of quality information you get when you ask the internet...
The General Tso is the next compressor in my wishlist - primarily due to @MichaelW 's regular testimonials. I think he's got build reports/ demos on nearly all of them - I'd go back and read through those if you're looking for a good comparison.
For the Creamery, it looks like the MPS4124 are not available on Tayda or Digikey. When I searched google for NPN TO-92, the 2N3904 came up. I'm going to have to do some research if I want to build that pedal.For a squishy effect, I vote for the Creamery.
For something utilitarian (like your Delegate Boneyard), Thumbsucker.
Then I'd build the General Tso,
followed by the Constrictor.
I myself wouldn't bother with the Byrdhouse, Dyna/Ross comps are a Dozen-a-Rupee. They work for other people, though.
Absolutely.I'm just guessing that there would be some people here who have built 2-3 different kinds. I think I've built 5 overdrive/distortions so far![]()
You should build a General Tso but with VTL5C4s instead of rolling your own LED+LDR, no headache and sounds *fantastic*.I've built the Delegate Boneyard edition. I think I messed up somewhere because it is EXTREMELY subtle. I can't get a squishy comp tone but it works well for sustain and boost. I'm thinking of building something that doesn't rely on a photoresistor.
Hold up, is that something I can use instead of an LED+Photoresistor? Like the 3 pins on each side go into their related components spots?You should build a General Tso but with VTL5C4s instead of rolling your own LED+LDR, no headache and sounds *fantastic*.
And fwiw I get as much compression as I ever need or want out of the General using led and ldr route.Those Vactrols are significantly more expensive than a led and photo-resistor.
Yeah but they work the first time, unlike the multiple combos of LEDs and LDRs I tried in my Tso.Those Vactrols are significantly more expensive than a led and photo-resistor.
I mean, technically, it *is* an LDR and an LED (inside a blackout plastic casing), but it’s manufactured and QA’d by a company with rep and customers to lose if it doesn’t perform up to spec in its intended applications.Hold up, is that something I can use instead of an LED+Photoresistor? Like the 3 pins on each side go into their related components spots?
