JTEX
Unicorn #2 is a Godin Multiac ACS Nylon that wanted a good home.
Where I live, Godin guitars practically grow on trees
@Harry Klippton
Nice! Did you use a hoist, or sheer Will? What size belly mower is that?
Looks like a Packard Bell 486SX to me.Looks like a CC 1450?
@Harry Klippton
From reading the post I think he just reached in there and pulled it outNBD
It's a Kohler K301. No hoist, just me. Manual says it's 118lbLooks like a CC 1450?
It's an Ampeg V4 cabinet I bought unloaded for $25 at a swap meet many years ago. I was hoping to restore it but it was very badly water damaged. Eventually I'll strip it of its hardware for another project and take measurements in case I want to make a replica of it@Harry Klippton What's the speaker box under the chop-saw?
That’s a great idea. I’ve always thought about doing something like that for my press, but so far haven’t had any issues with that cant. I would like to build some kind of jig.One of the great things about drilling with a step-bit is that once you get to your desired hole size, you can lightly touch down with the next larger step for a nice deburr/ chamfer on the edge of the hole.
This works out great on the face of the enclosure which is parallel to the back, but once you stand it up on-end there’s a casting angle to deal with. Drilling the holes on-angle isn’t really a problem, but the chamfers don’t work out as nice. I also drill the ends for nameplate rivets with a very small bit, and I don’t like doing that at an angle.
I’ve had a couple different setups for holding enclosures in the vise tipped back at about 2 degrees, but they all allowed some vibration, which makes for noisy drilling of the larger holes.
This is the newest version- I cut the face of this big chunk of plastic at 2 degrees, and set up a piece of wood to make contact at the bottom edge of the enclosure face.
I haven’t tried it yet, but it feels pretty solid.
Worked up enough motivation to clear off the bench and start getting stuff boxed
How do those stamps work? Are you just stamping each letter freehand one at a time? Is there some kind of alignment jig happening? The alignment and spacing is very good however you’re doing it.
