what does the cost per board look like for this version? also, what kind of i/o jacks are you using for the other board?
With an order of 5:what does the cost per board look like for this version? also, what kind of i/o jacks are you using for the other board?
Thanks.With an order of 5:
The IO jacks are from Daier:
- ~€3 per board without relay (this is mainly because there is a $7 setup fee for assembly, so the price should drop to ~€1.50 or lower once you go above 5)
- €1 for the relay
- €1.80 for the footswitch
- DC are DC-005
- 6.35mm are PJ-651A-01
Ohhhhh I want me one of these! Thank you so much for the files!!!!Because DIY is about sharing what you learn, what you get from others, paying it forward, and just having some sheepy love!
GitHub - szukalski/pedal-simple-relay
Contribute to szukalski/pedal-simple-relay development by creating an account on GitHub.github.com
Ha, ha! I also use JLCPCB and I’m thinking on buying parts directly from Daier to lower costs. Do you use EasyEDA? I would love a few tips about choosing specific components to generate an assembly order later.With an order of 5:
- €1 for the relay
- DC are DC-005
Thanks a lot. Makes me wonder, what was the reason to use 0402 size components? There is a room for 0603 and maybe even 0805 and that would be a bit easier to hand solder.Because DIY is about sharing what you learn, what you get from others, paying it forward, and just having some sheepy love!
Daier is great for hardware (switches, enclosures, knobs, jacks), LCSC is great for components in production (it's what JLCPCB uses), and JLCPCB is great for PCBs!Ha
Though I need to move a few components from the bottom to the top to have everything in one side, since JLCPCB only assembles single sides.
If you already posted something about this that I didn’t see, I would appreciate you pointing me to it. Thanks!
The pick and place robot doesn't complain about it. I just try and standardise my DipTrace component library. There are going to be instances where I need to go larger for power dissipation or because you can't get the voltage rating in that size, but 0402 is cheaper and smaller. What's not to love?Thanks a lot. Makes me wonder, what was the reason to use 0402 size components? There is a room for 0603 and maybe even 0805 and that would be a bit easier to hand solder.
Thanks a lot! I haven’t thought of simply creating a library myself. I always suffer selecting from 200 similar components with different prices from EasyEDA’s interface…Daier is great for hardware (switches, enclosures, knobs, jacks), LCSC is great for components in production (it's what JLCPCB uses), and JLCPCB is great for PCBs!
I haven't posted anything about the process, it took some multi-tasking to get the github repo set up
- I use DipTrace, but the same approach is true no matter what. You need to first get your component library setup, you can try and use an existing one but it's better to copy components from there into your own one for consistency (else you need to choose from 27 different 100k resistors each time).
- JLCPCB has a basic parts library which is best to stick to (any part outside that is extended and will incur a $3 setup fee per component type, they have to load the pick and place machine). I have shared my DipTrace library via the link in my signature, but EasyEDA has the JLCPCB basic parts library in any case..
The goal is to minimize cuts, jumpers and area. Pins 5 & 6 on the relay are n/c, so you don't need cuts at G11 & G15. It's fair game to make caps as long as you need to reach the desired strips.
Here's a scoring gauge I just made up:
1 point for each cut.
1 point for each jumper.
1 point for each unused hole. A hole is considered used if it is cut, covered by a component or jumper or used for an external connection.
It's like golf: lower score is better, it can be very Zen and it goes well with alcohol (not too much though).
My score:
12+8+10 = 30
That includes the jumpers on the solder side that join adjacent strips.
If you’re using a 9v relay, you don’t need to drop voltage/current, so you’d just use a jumper.i haven’t yet recalculated the correct/actual value to replace the 150R, but i will
YES.any errors?
i’m probably only going to do like x3 max. i don’t do heaps of builds.LCSC has suitable relays for cheap as chips and good shipping. If you're doing more than a couple relays, then having a vero may end up being a tedious, repetitive process for what is essentially a modular part. I just had 30 made with all the components on SMD except the relay for a buck a piece. With relay, it would have been ~$2.20 each (I just have an inventory of relays to use). That's not such a bad price if you build a lot of pedals.
thanks for the tipIf you’re using a 9v relay, you don’t need to drop voltage/current, so you’d just use a jumper.
That relay is not the size you think it is. Take another look at the datasheet.
