steviejr92
Authorized Vendor
Ok this makes sense, that just helped me put things into perspective a little better. Turning the treble is more or less making the higher frequencies relevant in the harmonics that the GAIN is creating.
			Thanks! I wanted to make sure.S2A & S2B are the two halves of a DPDT ON-OFF-ON switch.
Nice looking layout, @szukalski! I laid this one out back in May it was a bit of a PITA. I never ordered boards, but my layout looks similar to yours.Man.. that Celestial Overdrive is the hardest layout I've tried yet. I was tempted to make the tone stack a breakout board
I’m still not entirely happy with it. There are some tricky junctions which make it hard to be elegant. Yours looks great!Nice looking layout, @szukalski! I laid this one out back in May it was a bit of a PITA. I never ordered boards, but my layout looks similar to yours.
Switch pads are slotted but don't show up in Eagle's export.
Thank you sir and you're correct, I used the wrong footprint. If I get serious about sending this one off to JLC, I'll get that updated and put the board through the same updated EDA treatment as a couple of the others I've shared with you recently.Nice layout, Brett, you even got the relay switching on there. The MP38A footprint looks to be undersized. Appears to be TO-18, should be TO-39.
Send me the schematic for review if you like.
	I think you should call it Complex Red.Another coffee break and I am loving this with OA7 diodes. So much that I already got a faceplate in the works.
It is a play on words. California Red is a sheep breed (there has to be a sheep theme), plus it's a nod to the designer's location (it would be an added bonus if he has bronze facial hair genetics), and it's a tasty wine variety!I think you should call it Complex Red.
