 forum.pedalpcb.com
					forum.pedalpcb.com
				Thanks! I got Q1 & Q3 at about 9V. I couldn't get Q2 any lower then 11V because the trim pot was turned all the way.Also, check this thread for info on what to do in case you can't hit 9V (you might either have to up your trimpot size or modify a few resistor values)
Argentum 1212 200k trimpot for Q2
Built a couple of these and while Q1 and Q3 biased to 9v with room to spare, Q2 on the other hand would only go to 10.35v and 10.65v. MMBFJ201’s from Mouser all same batch. Wondered if anyone else experienced this and if the solution would be a different jfet for Q2 or perhaps a 150k-200k...forum.pedalpcb.com
Bummer! So yeah to get Q2 down to 9V, you might have to change TRIM2 to a 200K trimpot, or play with the value of R9, whichever is easier for you to do.Thanks! I got Q1 & Q3 at about 9V. I couldn't get Q2 any lower then 11V because the trim pot was turned all the way.
It's generally a rule of thumb to bias at 1/2 the voltage supply but it ain't written in stone.Based on this teardown video from Gray Bench Electronics, the original Jackson Audio version biases all the JFETS around 11-11.2V.
Too bad, a bunch of people in this thread and the other one are trying very hard to bias all of them down to 9V. I wonder why PedalPCB does not include biasing information in the build doc? Would have cleared up a lot of the above confusion and saved people some trouble.
Thanks for sharing this. Ya I thought mine sounded good at 11V and if it sounds good then I'm happy. But also glad it matches the OG pedal's bias.Based on this teardown video from Gray Bench Electronics, the original Jackson Audio version biases all the JFETS around 11-11.2V.
I saw this comment (see attachment below) in the comment section of the video. Thought it would be worth sharing here.Thanks for sharing this. Ya I thought mine sounded good at 11V and if it sounds good then I'm happy. But also glad it matches the OG pedal's bias.
I suspected this if no ground was through the plastic jacks, Gray Bench is human & is allowed to miss this if he didn't see a pot leg ground to pot chassis.I saw this comment (see attachment below) in the comment section of the video. Thought it would be worth sharing here.
Ya agreed, I wasn't losing any sleep over it either. like I said I'm happy with the way it sounds. But it is nice to have all the information in one thread post for anyone looking for similar information in the future.If it sounds good, it is good. Biasing voltages are a ballpark. Chill chill, my good people.
Yes yes, but I still want to know the OG pedal measurements, even if it’s only a starting point to say “This is how the real pedal does it, for better or worse.” I just don’t see an argument for omitting this information; why not let the builder decide to use it or ignore it. Fwiw Madbean, Dead End FX and others usually include such details.If it sounds good, it is good. Biasing voltages are a ballpark. Chill chill, my good people.
Did you read this regarding the voltages listed above regarding Gray Bench Findings???Yes yes, but I still want to know the OG pedal measurements, even if it’s only a starting point to say “This is how the real pedal does it, for better or worse.” I just don’t see an argument for omitting this information; why not let the builder decide to use it or ignore it. Fwiw Madbean, Dead End FX and others usually include such details.
I’m aware of the rule of thumb to bias at half the pedal voltage. But I’ve encountered so many pedals that don’t follow this rule, it’s become kind of meaningless
Regardless, it doesn't really change my grievance lol...I'd love to see that sort of information in the build doc, rather than finding it by chance in a Youtube comment.
For those of us in the know, we appreciate all that you do for us!! Hope you at least took Thanksgiving off!I wish I could tell you but mine arrived with all the trim pots at full CCW.... brand new, bias never adjusted before being shipped... seriously.
The 3PDT footswitch was defective, out of the box, so maybe that's why they didn't set the bias, they couldn't get it out of bypass.
Then there was this:
 . You’ve been kickin ass, seems like every week I get a notification of more pcbs incoming.  Godspeed, my man!
