Since the conversation has somewhat shifted over to 29 Pedals I want to point out something that has been bugging me lately.
Bear in mind I have not
tested this theory, but here we go...
According to all of the marketing hype: "The WHATEVER power supply accepts 7.5 to 35 volts of AC or DC (either polarity) with absolutely no change in tone."
The WHATEVER power supply works by using a full wave bridge rectifier to convert AC to DC, or correct incorrect polarity DC.
Once we have a DC voltage it is regulated down to 5V, stepped back up to +/-15V by a PWM circuit, then regulated
back down to the voltages required by the pedal it is paired with.
Here's what concerns me...
1) When powered by DC the bridge rectifier drops around 1 - 2 volts (give or take) and the 7805 regulator has a dropout voltage of 2V. This means when the pedal is powered by the advertised minimum (7.5V) the MAX743 IC is getting around 4.5VDC. According to the datasheet it needs 6V for proper operation. I can confirm that the pedal
does function when powered at 7.5V, but this seems a bit borderline to me.
Now this is the big one...
2) When powered by AC a full-wave bridge rectifier outputs a DC voltage approximately 1.414 times the input voltage.   This means if the pedal is powered on 35V AC the 7805 regulator is being blasted with 49VDC.    The 7805 has an absolute maximum of 35V.     I can not confirm that the pedal will function properly on 35V AC......
I want to believe 29 Pedals has actually tested the pedal at the advertised voltage ranges and didn't just assume that because the 7805 can handle 35VDC then the entire circuit can as well.    Maybe we should find out what happens?
 This
This is why the IDGAF power modules will list two different voltage ranges,  one for AC and one for DC, because they are
not the same.
