So what did the natas end up being?
Sound like the Too Hard Basket just to go CHUG.I still have a lot of SMD capacitors to remove and measure, but basically it is: Boost > 3-Stage Cascaded JFET Amp sim > 5 Opamp stages of EQ/tone shaping > Output buffer
The boost is not exactly like a TC Pre but I would assume achieving a similar goal.
It's far from a Tubescreamer.![]()
Five stages plus a buffer, so three TL072s. (and a TL071 for the boost)SMD, probably a 4 layer PCB, Did you say Jfet's & 5 Op Amps!???
Yeah, 4 layers would be way too hard to break by handNot for me!
Make sure you include the “mode” switch in the PCB please. Other traces do not include it. I have this pedal and I love using it as an OD on the “drum” setting - gives it a nice bump in volume and mids.
Did you put the goop on, then take it off?
