My experience is it ends up in between a Linear & Log taper, C taper comes on way ealier!?The a50k with the 47k resistor on the outside legs will be close to 25k total resistance, but if I'm thinking right the taper will basically be reversed so it'll be close to c25k?
Ah yes, I did this once before for...something...As a very last resort, use the C25 & cut the 2 outside legs shorter & use the middle leg in PCB.
Run a fly wire from Leg 1 pot to pad 3 PCB, Leg 3 to Pad 1 PCB
Oh wow, interestingYou can covert a B25k to an A25k by soldering a 4k7 resister between pin 2 and pin 1 (sometimes its pin 3) of the B25k pot. You have to take a look at the circuit to figure out if you want pin 2->3 or 2->1; one will change the taper to C, one will change it to A. I've done this loads of times, here is a reference:
A25k in Pharmacist is connected as a variable resistor (two terminals). It is not possible to change the linear characteristic of the potentiometer to logarithmic in such a case. No resistor will help. This trick works for the potentiometer wired as a voltage divider (three terminals).You can covert a B25k to an A25k by soldering a 4k7 resister between pin 2 and pin 1 (sometimes its pin 3) of the B25k pot. You have to take a look at the circuit to figure out if you want pin 2->3 or 2->1; one will change the taper to C, one will change it to A. I've done this loads of times, here is a reference:
