Bring out yer Diptrace
That looks really cool! I've never used a depletion mode mosfet before. How are you using them here? And would you be willing to share the schematic?
I've never used them but on paper they seem pretty cool. One thing I'm worried about, and probably should have thought more about, is that they might turn off on the negative swing of the signal in some places here. But half the appeal of depletion mode mosfets is that you don't need to bias them to turn them on so we'll just see what happens without biasing them.
This is just a simple boost -> phase splitter -> differential long tail pair octave -> boost. Seemed to work in LTSpice. I've done variations on this theme with enhancement mode mosfets and BJTs
de-uglified a previous board design. can work in a 1590B or 1590N1. This one I could match to PPCB drill pattern. Anyone have a quick link to the Tayda Drill Tool version? (I'm working with 0,0 middle of the enclosure origin now) Don't suppose it'd be in mils :p
oops. need to adjust some of those value bits to fit.
This is what I go by:
https://forum.pedalpcb.com/threads/getting-drill-guides-from-eagle-pcb.15025/post-173650
Alright we're fixed and aligned to the tri pot setup that PPCB uses! This should work in both B and N1 enclosures with top jacks. Made some tweaks in an effort to give myself a consistent look: IO, LED, and power pads, etc. Took out the Platinum Chip, because it was just getting too busy, even for something you won't see…
I know it looks wonky, but the custom (elongated hexagon) #1 pads on the pots will be there in the final form. Although arguably this makes it look even wonkier hahaha:
Based on a test upload to JLC, it will drill out properly.
This came out glorious. Great work!
Are the IO pads 5.08mm spacing?
Look too far to be 2.54...
I could use some help (I hate asking for help) and I'm probably doing something stupid. I can't figure out why I'm getting clearance errors on my copper pour. got any ideas what I'm doing wrong here?
Your Design Rule is set to warn you if the copper pour gets closer than 0.635mm from the edge of the board, but your copper pour clearance is set to extend 0.33mm from the edge.
Either change the clearance to a value higher than 0.635mm or change the design rule to accept something below 0.33mm.
I generally make sure there is some wiggle room there, if you set the design rule clearance to the exact same value as your actual clearance it'll throw an error on rounded corners.
Not DipTrace, but I've been playing with KiCad because I generally work on Mac and DT sucks there.
There's a learning curve but I have to say that KiCad has a lot going for it, it just feels less clunky and there's cool stuff to do.
Took me a while to build my footprint library again..
Check out that backside..
