That's a good point. That enclosure has a beautiful powder coat both inside and out, but that may be part of the problem. Ultimately, you want that enclosure to be grounded so that it will act like a faraday cage and shield the electronics inside. You might want to sand it down on the inside where one of your 1/4" jacks goes through the enclosure.In addition to the mess of wires, your enclosure might alsonkot be grounded properly.
Here's the problem. Charge pump is garbage. I switched out the 1044 with a lt 1054 ( same pin out) . Problem solved.
many of us have used TC1044SCPA as specified without issue on this build.The bom on the lead solder should be changed to lt 1054 for the charge pump. I have been chasing noise for a while and that finally solved it. I built 2 side by side and they were both the same way.
Totally, I had to ground a few things but it all worked out in the end.many of us have used TC1044SCPA as specified without issue on this build.
the great thing about using sockets in these builds is that you can use whatever IC you want
e.g. i've had builds that specified a ICL7660S, and it made noise, so i tried a TC1044SCPA, and that solved it.
shit happens I guess.
if you managed to solve the problem, i'd call it a win
Was it an oscillation that changed with the gain knob? I’m working on that issue, too.Here's the problem. Charge pump is garbage. I switched out the 1044 with a lt 1054 ( same pin out) . Problem solved.
Sorry for the vague info. It works to a degree. Lt1044CP and 1054CP The pedal cuts out with the gain at noon or higher. If anyone has voltages, that would be helpful. Only sub was 8M for an 8M2.LT1054CP? IP? What have you used? Great to know It. If It works, is good to know It. Thank you very much
