They’re like $150 on amazon so I ended up paying $200 after getting some vinyl rolls and transfer paper...How much did the cricut machine set you back?
Nothing just 0 ohm resistorsLooks excellent. What do the resistors between the 3pdt and main PCB do?
Just looks cleaner to me
Let me check it outVery nice and clean build as usual!! How's your bone knob range ? Just finished mine and I only notice a change in the last 20%
Thanks for checking! I used tin can versions of the 2n2907 so I thought maybe I had a issue with mineYeah it’s the same on mine...
The only thing it affects under 20% is on the sustain...
Late reply, but I thought it may be worth it. I recently built a couple of these and had the same experience with it not quite reaching that “trumpet/trombone” sound with various transistors in the 187 hfe range. Found these metal can 2n2907a’s at SB and a lot of them were right in that range. Fortunately, I socketed the board and when I threw one of those metal cans in (183 I believe) it came to life. Maybe a little mojo is all you need at times.Yeah I did some research and they say that the hFE on that transistor is 187Hfe but I couldn’t find anything on the other one... so none of the can ones I had measure in that range... I had some MPS2907A that was perfect... and I socketed the other one and tried a bunch of different values and they really didn’t have any affect... I never could get it to sound quite right... or like the real one... but it is a real good sounding fuzz...
