BuddytheReow
Moderator
I've got my eye on some modulation boards and the Module8 seems like a "jack of all trades, master of none". Anybody built one and can comment on the toanz?
I always get side tracked and forget about the module 8 algos but still curious as to how they soundI've got my eye on some modulation boards and the Module8 seems like a "jack of all trades, master of none". Anybody built one and can comment on the toanz?
You mean something like this?I am a bit curious. Another cool thing is for 8 more sounds, pop in the octagon EEPROM.
It would be cool to have a bank switch to switch between two eeproms
drive.google.com
I did a bit of searching. Looks like maybe the Butt Stuff?I can't remember who here created the boards, but they shared the files and I got some from jlcpcb.
I built one forever ago, it's fine. Jack of all trades, master of none is a pretty accurate description.Sounds like nobody's got one of these. I guess this one may go up the build list to find out one way or the other.
To further clarify BtR's post, with the Module8 you have access to 8 algos in a single pedal, but only one can be used at a time.So I'm still a NOOB. Do you have access to all these algorithms at the same time or is it a pick one to use and build another pedal? Still trying to learn. Thanks!
