So I'm still a NOOB. Do you have access to all these algorithms at the same time or is it a pick one to use and build another pedal? Still trying to learn. Thanks!
To further clarify BtR's post, with the Module8 you have access to 8 algos in a single pedal, but only one can be used at a time.
You don't need to build a second pedal.
If, say, mid song you need to switch out from Flanger to RingMod, you'd have to reach down, turn the dial from Flanger to RingMod — you don't need to build a Flanger-Module8 pedal and a separate RingMod-Module8.
Also, if you prefer, you can order the "Arachnid" and select which 8 specific algorithms you want (for example, you could replace the two Tremolos of the Module8 for a reverb and a delay — Module8 is simply a pre-selected EEPROM used on the Arachnid platform).
You'll find a complete list of algos in the
EEPROM BUILDER section of the store.
Took me a while to wrap my brain around all the FV-1 stuff offered by PedalPCB (*and other DIY resources).
