Stickman393
I mean, yeahJust 3/4" plywood. It's like a set of drawers if you turn it sideways. I just made it sized for the bin cabs that go inside. 3/4" ply is overkill on the "drawers" but I had a bunch of 3/4 sheets available in the wood shop and some time to kill. The next set will likely be 1/2" ply for the "drawers". The drawer slides are heavy duty ones which are necessary for the weight of the drawer on the bottom slide. I have some HWIN rails left over from another project and may end up using them instead - two rails on the bottom and one rail guide on the top.
Other news...fuck my life. My 4mm cutter preset had been fat-fingered with a 1mm programmed diameter.
So my lower plate is about 1.5mm overcut. Balls. Gotta re-do the thing.
