I'm okay with this being an experiment. A few months ago I made another version of this circuit but in a much more condensed form factor. I'm going to use this circuit as a control as I learn about PCB design, so I can have something constant to compare different layouts.Hopefully you have no crosstalk between the in and out traces.
Don’t think it’s high gain enough it will matter tho. Time will tell.
If anything you can run the input and output on different edges of the pcb.I spaced out their long traces to be equidistant from each other and the edge of the board. At the footswitch, their close proximity is unavoidable, so I'm not so much worried about that.
yeah it's hard bc I want the footswitch hanging off the end of the board because I like it as far down as possible, so space is limited. If i ran the in/out traces on either side, then the trace connecting the bottom left and bottom right lugs would interfere with the bottom center lug of the footswitch's ability to connect to the IN of the circuit. Because I put all the signal traces on one side for some reason idk. For this, I redid the pinout of the switch to allow the traces better access to the lug pads, but the result is both in/out on the same side.If anything you can run the input and output on different edges of the pcb.
I've noticed that even with my worst designs (aka first ones) I haven't had any problems with the traces causing oscillation or interference. I suppose I could go dig out my engineering books and look it up.. but where is the fun in that?![]()
would you not just stick the LED switch in the middle?If i ran the in/out traces on either side, then the trace connecting the bottom left and bottom right lugs would interfere with the bottom center lug of the footswitch's ability to connect to the IN of the circuit.
The LED switch could go in the middle, but check out the trace that grounds the input of the pedal when the circuit is bypassed.would you not just stick the LED switch in the middle?
You have my full and undivided attention. And that name is perfectPutting the finishing touches on this take on the Hudson Broadcast/Dylan159 Narrowcast. It's got a germanium Q2 (with a few resistor tweaks to accommodate it), a charge pump, and a switch to select between 9v and 24v operation.
I finally had a chance to try out assembly, and it's a bust. I tried 3 different approaches - first was to pivot the board in, then I tried having the entire board slot into the top and then push forward so the audio jacks would seat, and lastly I tried opening up the audio jack holes into a tombstone shape with their bottoms open so the board could just be inserted vertically. I don't really want to get into describing them in detail because none of them worked! Drilling circular holes is relatively easy, but making slots is very difficult, so the first two methods are out. The last method was the closest to working, but there were two problems: the audio jack washers didn't entirely cover the gaps at the corners of the holes, and because I had to mount the board as close to the bottom as if would go, in the 125b enclosure my footswitch was shorter than I would have liked, and the toggle switch did not reach the surface at all.I'd love to see a pic when you are done - I wonder if the height and flexibility of the long pins will give you the room you need to maneuver the audio jacks where you need them.
There's also this DC jack from Wurth electronics which I think is what the cheapie Taydas are modeled after, if you need to squeeze the top tighter together (It might buy you a couple mm!)
I remember reading Tayda can drill irregular shaped holes, but I drill mine on my drill press at home after paint, as having the holes predrilled interferes with the way I paint them.I wonder if you could do a custom 3d-Printed washer/grommet to do the slot/tombstone style.
Oh, or maybe you could do a faceplate (sideplate?) on that side to mostly hide the slots.
(Though I'm not sure how you'd have that drilled, I dunno if Tayda can do it and it seems like a
hassle to do at home)
I have seen pictures of other pedals built that way to solve this problem, but it's inelegant unless
you could cover the gap.
what on earth is it?After what feels like 800 years of working this I finally cleared up all my DRC errors.
481 vias lol
It's my latest attempt at a better tube tester. It's a giant mess.what on earth is it?
