Thanks!Faultless! that's absolutely pristine
Pretty slick. Do always use vishay resistors? I like em but find they’re often too big. Some of the 1/8 watt ones are bigger than your standard 1/4 watts.
Thanks! Yes, mostly I use vishay cmf-55 (0,5W). They fit everywhere without any problems.Pretty slick. Do always use vishay resistors? I like em but find they’re often too big. Some of the 1/8 watt ones are bigger than your standard 1/4 watts.
Thanks! Yes, it's much easier to tailor the length. You also can change the led color without soldering...Socketing the led is the best idea I’ve seen today. Totally going to use that. Thanks.
Thanks!Phenomenal. Looks amazing.
Thanks!Nice and clean. Love it!
Thanks!Clean build. Hats off
Thank you!This is exceptional, one day I'll get there.
The biggest thing that blows my mind is how clean the solder joints are. Are you using some crazy industrial solder gun or just exceptional technique? ?Thanks!
What type of Polish do you use!!!
