This is about the fourth time in a row...
A couple of times I forgot to solder the switch PCB to the switch, and then wondered why the switching and led were acting so flaky.
But my biggest goof is when I was debugging a pedal, and I had repeatedly plugged the guitar into the pedal output, with the pedal input plugged into the amp. I kept reflowing solder joints and trying again and again, with the same results. What's deceiving is that the bypass signal works in this case. Wasted an afternoon on that one.
... that I’ve fired up a build to test it, had no sound, and started meticulously going over every joint before realizing I forgot to put the ICs in the sockets.
Anyone else care to share their facepalm moments?
I've built like 5 Uberfuzzes, and a few days ago for the first time I couldn't get one working, then I realized I hadn't adjusted my pinout for my transistors (had to swap legs 2 and 3). Had to remove ALL SIX transistors and redo them around an already populated full PCB. What a headache. I've also put ICs in flipped the wrong way, or NOT WIRED THE OUTPUT AT ALL. Ya know... fun stuff.
I thought I was the only one that thought pimentos grew in olives. I didn't figure it out till I was, like, 30.
I've tacked in 8 pin sockets to get them level and forgot to go back and do the other 6 pins. It was a circuit that had 7 of them and I stared at it for quite some time before having the "oh man" revelation.
With the Amentum build I finished today I had a few moments of panic because when I engaged the effect the light came on and my bass signal cut out. I was about to take it back out to the garage but discovered that the knob cuts all the volume when fully off. Never had a pedal that did that before.
I've learned what the smell of melting blue tack is ... and honestly - it's kind of pleasant. Much better than melted shag carpeting.
When I first started using it I'd just smush a glob on whatever I needed to solder and I ended up melting little bits of it all over the board. I had no idea what it was for days as it kind of looked like leftover fuzz from paper towels (but I use KimWipes!) and it created one heck of a mess. I learned to be a bit more careful as to how I attach things with it now.
I still haven't learned how to not do this, so I stopped trying to use it.
I check the polarity thread every.. single..build
I made a cheat sheet poster that's hanging above my desk with all the common wiring things I'd want, schematic symbol reminders, final assembly checklist, etc.
I found that rolling it in to snakes works pretty well. Keeping it off the leads is the main thing.
I do the snakes as well. I’ve found that the most common mistake is using too much. Very little will do the trick. Also don’t try pulling it off while things are still hot. Pulls off much better when cooled down and then roll it in to a blunt point and use it to blot up any remaining bits. It picks itself back up pretty well.
