Those knobs look really clean. Where did you get them from?This is a really good build...
The speed doesn’t get too fast but it’s an awesome build...
Stomp box partsThose knobs look really clean. Where did you get them from?
Thank you! It seems based on the silkscreen that you're supposed to use these? Or are any MKT fine?Those are Wima caps
And the electrolytics are würth capacitors
got both of them from mouser
Yep that’s what I used...Thank you! It seems based on the silkscreen that you're supposed to use these? Or are any MKT fine?
Is this the correct item? https://www.mouser.com/ProductDetail/505-MKS21.0-63-5
I can barely tell mine is on!
Are your ICs from a reputable source?I watched a demo of this pedal to get an idea of how it should sound. Yeah mine does none of those sounds. Back to the drawing board.
I was told to get them from cabintech. The first set was bad, the 33r was burning up. I put a new 3207 in and it stopped getting hot and the voltages got better. So idk.Are your ICs from a reputable source?
How did you set the trimpot?
You adjust for maximum chorus effect without distortion. If you don't hear a chorus effect you can't really determine that the trimpot is adjusted properly.
Turn Depth to Maximum.
Start with the trimpot at full CCW, then slowly turn it up until you hear chorusing. There may be a very narrow portion of rotation where you hear the effect. Once you find the range where you hear chorusing gradually tweak until you get the maximum effect without distortion.
It can be very touchy and is easy to under/over shoot the sweet spot
What I’m saying is I set the depth to max and did what the instructions said. Depth to max and turning the pot left to right doesn’t change anything. You can tell there is a very slight chorus sound but it doesn’t get more or less turning the pot. Sorry if I’m not explaining myself correctlyHow did you set the trimpot?
It can be very touchy and is easy to under/over shoot the sweet spot.
