and is there a template for the jacks?
Any idea if /when these will be available again?Yep. Neither of these are new, they've been available for a couple years, they've just been out of stock for a while.
I use the top jack template for almost all of my builds except projects that have a special template.
The 125B enclosure template doesn't work for all of the projects obviously, but when it is compatible it sure as heck makes things a lot easier.
So I am not the only one?So what you're saying is that I'll be placing my 6th order this month? Got it.
Also, just got the front template today, is there a way to tell whether the inner vs outer holes should be used for each build other than measuring (does the 3 knob always use the outer, 5 knob uses inner or something similar)?
Awesome, thank you!They arrived today, everything still has to be counted/added but expect them sometime tomorrow.
The best way if you're unsure is to compare against the paper printed template. In most cases the 2, 3, and 4 knob templates will use the inner set of holes (1.3" spacing) and the 5 and 6 knob templates will use the outer set of holes (1.6" spacing).
There are a few exceptions, but this is usually the standard.
