The board has been verified and you can use the faceplate to drill the holes. Its not ideal but it works
It’s has an onboard charge pump combined with a 12v regulator so you can supply it with 9vdc.
Also looking for the Electrovibe build docs lol. Mostly needing the drill template specifically.
I also would very much appreciate the release of the build documentation. In particular I would need to know the wiring. Where is the input and output on the PCB? How are the two switches wired?At the risk of sounding like a huge PITA, is there an ETA the Electrovibe build docs?
From what I can gather, the Vibe switch is wired as usual, the left most hole goes to the tip of the input jack, the rightmost hole to the tip of the output jack. The 4 holes in the middle go to the 4 holes in the PCB right above it in the usual PedalPCB order (L to R: in, gnd, sw, out).I also would very much appreciate the release of the build documentation. In particular I would need to know the wiring. Where is the input and output on the PCB? How are the two switches wired?
Tanks for any help.
The Speed switch has a breakout board with 9 holes that match exactly the 9 holes in the PCB above it. They correspond to the 9 lugs on the footswitch of course.
